Earthed metal protection | Page 3 | on ElectriciansForums
Discuss Earthed metal protection in the Australia area at ElectriciansForums.net
hi there
may need to bury some meter tails in wall (25mm 16mm earth), not my usual practice, now they will not be below 50mm so they will need earthed mechanical protection. can any one advise as whats best to use for mechanical protection and the size of the earth cable required for earthing it ?
many thanks
What I can't picture is what if, like any meter tails anywhere they are not goint to run in a straight line, So yes stick them in scaffold tube and earth it but it's going to be one hellava fabrication job getting the tube to bend even a little to get past the obstructions we meet every time you run 25mm cable, what about the pre armoured stuff, not swa, I cant remember who makes it, does that go up to 25mm??
Pict
Reply to Earthed metal protection in the Australia area at ElectriciansForums.net
Sounds like a Standard (12kVA) supply then. So minimum of 10mm^2 Earthing Conductor and Main Equipotential Bonding Conductors.
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
