With regards to electrical continuity across pipe flanges to bs 7671 I cannot find anything on how to size flat braided cable. Could someone point me in the right direction please is there a rule of thumb with regards to bolt size? Thanks
Discuss Earthing across flanges in the Talk Electrician area at ElectriciansForums.net
Why would you want to? don't the big bolts form a good enough connection? done any testing.With regards to electrical continuity across pipe flanges to bs 7671 I cannot find anything on how to size flat braided cable. Could someone point me in the right direction please is there a rule of thumb with regards to bolt size? Thanks
I think the site has a belts and braces approach. From what I have seen the straps are different across flanges of the same size. Can’t see anything in bs7671 with regards to sizing them?
Reply to Earthing across flanges in the Talk Electrician area at ElectriciansForums.net
