Earthing Arrangement | Page 2 | on ElectriciansForums
Discuss Earthing Arrangement in the UK Electrical Forum area at ElectriciansForums.net
Glasgow
[ElectriciansForums.net] Earthing Arrangement
Hello,
Currently still studying at college. I seen this yesterday on a site. I asked the question but didn’t really get a good answer.
I think this is tns. I see 2 10 mm on the left going to water and gas, 1 10mm going to the board. But where is the cpc coming from to connect back, I don’t see any connection near the cut out.
Thank you
Curious Student
That is a service terminal block, I know it has Henley on it but it is like calling a consumer unit a Wylex:D
Indeed. Here they call them ISCOs rather than Henley but I agree that a service connector is a more accurate name for them.
With only that one picture to go on I’d say it’s not possible to confirm anything. My guess would be that the service is TNCS but the earthing conductor has not been installed and the installation is relying on the bonding for an earth connection.
Hopefully a wider view of the setup would reveal an earthing conductor which we can’t see from the picture.
Technically calling them ISCO is the same as calling them Henley, ISCO was W.T. Henley’s range of ironclad service cutouts etc for use with PILC cables.
I agree it's no different. Just pointing out that Henley block is not used universally.
Reply to Earthing Arrangement in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
