earthing arrangement | Page 2 | on ElectriciansForums
Discuss earthing arrangement in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Your swa is compromised, by all means TT the system. As long as full RCD protection is installed. But as E54 has said the cable has been damaged. It's not gona be long before your back here asking what to do with a Phase to earth fault... Find out why the swa failed and work from there.. TT ing the system is a half assed way of getting out of doing the job proper
Reply to earthing arrangement in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
