B
BertUK
i have to run a good length of 16mm swa to a garage 65 mtrs away from the main house to run some sockets and lighting,the system is tn-c-s,the existing earth csa is 16mm,i intend to fit a 63A fused isolator in the meter box via a henly block from the existing 25mm tails,can i run a 16mm earth from the neutral block in the cutout to an earth block then run a 16mm earth to my isolator and another to the main board in the house.
