Earthing cable running through kitchen cupboards | Page 2 | on ElectriciansForums
Discuss Earthing cable running through kitchen cupboards in the UK Electrical Forum area at ElectriciansForums.net
W
WellBonded
Hi,
A few days ago I posted a question regarding some earth bonding work that was recently carried out at my home. The question was about bonding to the main incoming earth.
Today I have noticed that the cable which bonds to the water main has been run through the interior of two cupboards (a food cupboard and the cupboard under the sink), rather than the service void that exists behind the cupboards.
When I was initially shown the work, the cupboards were full and I could only see that the cable attached to the stop cock and appeared to run along the service void.
Having emptied the cupboards today, it is apparent that the contractor has run the cable inside the cupboard for the majority of the route (as shown by the attached pictures).
There is access to the side of the service void (although it is enclosed with a wooden panel). It would have been somewhat fiddly to drill a hole and feed the cable, but possible.
I suppose this is not immediately dangerous, because it is not a live cable, but it strikes me as a shortcut and as poor workmanship.
I wondered if anybody had any thoughts on whether this was at all acceptable.
Any input would be much appreciated.
[ElectriciansForums.net] Earthing cable running through kitchen cupboards[ElectriciansForums.net] Earthing cable running through kitchen cupboards
Yep!! ..... That's the stuff!! ;)
but what if the space under the cupboards is an escape route? then you'd need to secure the cable with metal fixings/clips.:49:
That doesn't answer the question! Laying on the floor is supported as stated in bs7671, the question was where in bs7671 does it say they must be clipped?
I knew you were going to say that. Clipping is one way of supporting. I would not consider lieing on the floor as giving the cable support. Would a cable lieing across a suspended ceiling be ok?
I take you are not an electrician then if you have to ask whether a cable lying on a suspended ceiling is ok or not. It is not ok, a suspended ceiling does not provide suitable support, has many metal edges that could damage the cable and the cables would prevent/hinder access into the void above.
A floor however is adequate support as it is a solid structure intended to support far greater weight than that of the cable. BS7671 states that a cable lying on such a surface is adequately supported
Reply to Earthing cable running through kitchen cupboards in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
