earthing conductors | on ElectriciansForums
Discuss earthing conductors in the Australia area at ElectriciansForums.net
sparks4
hello can anyone help me all i want to know is are 4mm main earth and main bonding conductors ok? as in passing a periodic inspection?
its a tns
external is 0.06 ohms
pfc is 2.9ka
talis are 25 mm
and it has an 30ma rcd main switch
i always asumed to minimum was 6mm but someone is questioning my snag on my report
many thanks:cyclist:
I've not got my BGB to hand but a rough calculation tells me that the mimimum required csa of the earthing conductor is around 8mm, so it should really be a 10mm cable in there. I assume the cutout fuse is a BS 88?
Reply to earthing conductors in the Australia area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
