Earthing conduit | on ElectriciansForums
Discuss Earthing conduit in the Talk Electrician area at ElectriciansForums.net
Y
YTSOxford
Hi all. Just a quick question for the more experience sparkies out there.
Haven't done alot of conduit work before, so am not sure babout bonding.
I'm helping to second fix a job and the builders have removed an internal wall, leaving a leg of the ring and shower cable.
Since the runs aren't in the zones of accessories or in the corners of the walls, I am sure they should be in earthed metal conduit. But where do I take the earth?? Does it go back to the MET or can it go to the earth terminal in one of the associated JBs in the roof space??
I would like to wait for one of the other sparks to do it, but if I know the builders, they will burried it the plaster, and foget about it......until the customer puts a picture up!!
Thanks.
Have you checked if theses circuits are RCD protected ? if so they dont need to be in metal earthed conduit .
HTH
If the cable is not in a prescribed zone then yes it needs to be in steel conduit and can be earthed via a local circuit jb in the loft.
Reply to Earthing conduit in the Talk Electrician area at ElectriciansForums.net
And if it's a garage then use metal clad accessories.
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
