Hi all,
I'm in need of a bit of clarity on this decision.
So, long story short... have been asked to quote for the installation of some electrical services. Property is a small holding, my bad, but didn't check existing earth as there was a lot of items discussed (given it's location, I suspect it's TT as it's an overhead supply), but key ones are provision of various bits outside in a barn and a shed. Barn is attached to property, shed is not. So, I'm planning a small plastic CU inside a weatherproof steel cab inside the barn, fixed wiring will be SWA to try and reduce rodent problems.
My plan is to provide an earth in the vacinity of the barn by way of a rod or structural steel that penetrates the ground (if there is any, not sure there is). If the structural steel doesn't penetrate the ground, I'll be bonding it anyway. Thus creating a TT installation for the outdoor power.
Supply to barn is from main CU by way of a 30mA RCD protected circuit, so I don't need to worry about localised RCDs. I know it would be preferable to have the RCDs local to the board, but the cable is already in place, it's T+E and runs through the building so I'm inclined to leave the RCD at the source.
Am I on the money or way off? If you guys need more info, please let me know and I'll be happy to provide
