Earthing from over head lines... | Page 4 | on ElectriciansForums
Discuss Earthing from over head lines... in the Australia area at ElectriciansForums.net
fareham
Need to do some work on a house, detatched with overhead lines supplying it.
There is a cut out in meter cupboard then tails inside the house to an RCD or ELCB, then into ccu.
There is no earth present just the tails going throught the RCD in the CU.
My question is.. How can i tell what the earthing system is supposed to be? I need to add a garage unit for solar should i earth stake it? i need to add bonding as its non existant so i could also add that to the stake earth but i dont want to add a potential difference between the earths. There is no existing stake.
Could the earth be taken from the neutral in the ccu to act as a PME type system?
Not come across this before so any help much appreciated.
Well,if you are going to be called by a girls name,I suppose you could get worse than Sharon,
Something like Olivia or Penelope may have been a step too far
[ElectriciansForums.net] Earthing from over head lines...
Reply to Earthing from over head lines... in the Australia area at ElectriciansForums.net
Just an update for anyone interested, I got another rod in outside today, which has lowered the Zs db to a more healthy 53ohms. The oven elements...
4K
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
