L
Lucas
Always earth the box, was always taught to. Don't like seeing on leg of the earth bent over into the terminal and then onto the frontplate, if it snaps you have the potential of an open circuit
Discuss earthing metal backboxes in the Talk Electrician area at ElectriciansForums.net
If any cable snaps at a termination, you will have open circuit? therefore we take precautions not to snap the cables and to test on completion to see if they're snappped.Always earth the box, was always taught to. Don't like seeing on leg of the earth bent over into the terminal and then onto the frontplate, if it snaps you have the potential of an open circuit
basically the metal back box requires earthing , it relates back to regulation 8 of the electricity at work regulations 1989
which states precautions shall be taken ,either by earthing or by other suitable means as to prevent danger ,
i.e a danger could be present if a line conductor comes a drift we need to make sure the fuse or breaker disconnects ,
again 99 times out of a hundred i will have say 3 earth cables in a ring main socket earth terminal the reason for this years ago i looked at the risk of people getting say an electric shock and decided that the larger risk came from the accessory metal plate or plug or after the plug so common sense dictated the lowest path of resistance would be connecting all three earths together ,plus over time doesnt the damp and plaster turn the metal back box terminal green increasing the resistance of that connnection
please also note i still consider myself the apprentice at 49 years old , cheers
i'll be the first person to say i don't put a fly lead on. No need to and those that say it only takes 10 seconds longer are dreaming. You must have good prices in. Switch of supply before removing cover applies to sockets aswell
Billyhas, there's no need to look both ways when at a zebra crossing because the drivers are legally required to stop for you but we all do don't we
Strange anology. Do you really think there is no need to look both ways at a zebra crossing?
Ok granted a little bit of a strange analogy but the point I was aiming for is do you think that belt and braces is a good idea? I do.Strange anology. Do you really think there is no need to look both ways at a zebra crossing?
So no earth on the metal box, someone unscrews the socket whilst the circuit is still live, the installer had nicked the live when they stripped it or no grommet and the stripped live touches the box.
Or the live pulls out the socket when it lifted off and touches the box.
I've always earthed boxes, including metal adaptable boxes even if they didn't have an earth lug.
There are plenty of Good Practices that aren't in the Regs, yet.
The back box is earthed by the screws when the faceplate is screwed back. The argument of what if someone unscrews the faceplate and touches a live box, to me, is invalid. As its exactly the same as saying what if somebody unscrews a consumer unit and inadvertantly touches the buzz bar.
End of the day unless competent they should be opening anything electrical especially live.
I agree as an extra precaution it's great a d good practise. But not bad practise if you dont
Reply to earthing metal backboxes in the Talk Electrician area at ElectriciansForums.net
