Earthing systems explained | on ElectriciansForums
Discuss Earthing systems explained in the UK Electrical Forum area at ElectriciansForums.net
So where does this Earthing method fit into the scheme of things??:eek:
[ElectriciansForums.net] Earthing systems explained
Reply to Earthing systems explained in the UK Electrical Forum area at ElectriciansForums.net
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
You would treat it as a TT installation.
