Earthing systems | on ElectriciansForums
Discuss Earthing systems in the Australia area at ElectriciansForums.net
C
Cj24
Hi can someone help and help explain the earthing systems for example TNC-S is terre neutral combined separate, but does this mean the earth and neutral come into your property combined then separate etc and what about tt which I know is via a earth rod but tns and tnc sustems
TN-C-S= The earth (supplied by the distributor)and neutral are combined up to the origin of your installation
TT= A distributor's earth facility is not supplied hence the need for an earth rod
TN-S=There is an earth supplied by the distributor which is seperate from the line and neutral often using the armoured sheath of the supply cable
Obviously these are very brief descriptions
PME= protective multiple earthing: PEN conductor generally rodded/taped to earth at regular intervals along its length.
PNB=protective neutral bonding: PEN conductor as with PME but not rodded/ taped to earth along its length but relies on the star point being earthed. Generally used to supply a single installation.
Part of the problem of understanding these systems is that quite often the DNO's use different terminology to us.
For example, they commonly refer to TN-C-S as PME. But they also have PNB, SME....
In fact, it would probably be a very useful sticky to have this all as list by others on here with DNO experience to act as translators (not me!).
Reply to Earthing systems in the Australia area at ElectriciansForums.net
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
Better/Smart/intelligent/expensive generators require two earth spikes set ~10-15m apart. They check the resistance between spikes and will...
