Earthing systems | Page 2 | on ElectriciansForums
Discuss Earthing systems in the Australia area at ElectriciansForums.net
C
Cj24
Hi can someone help and help explain the earthing systems for example TNC-S is terre neutral combined separate, but does this mean the earth and neutral come into your property combined then separate etc and what about tt which I know is via a earth rod but tns and tnc sustems
Reply to Earthing systems in the Australia area at ElectriciansForums.net
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
In TN-S systems, you shouldn't isolate the neutral in a 4-pole isolator. Connecting neutrals to a dedicated terminal is acceptable and safe...
