earthing the SWA cable armour in a rotary switch? | Page 3 | on ElectriciansForums
Discuss earthing the SWA cable armour in a rotary switch? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Morning... sort of for me.
Have just got my rotary switch for the Hot tub and notice there is no room for a banjo inside as the front cover fixing holes are in the way. Just wondered what you guys do with this type of rotary switch? Perhaps a piranha earthing nut?
Have just contacted the local wholesaler who I have started using and he said the chaps dont usually earth the armour in a rotary switch which was a bit of a suprise!!
[ElectriciansForums.net] earthing the SWA cable armour in a rotary switch?
i just add the cost of the nuts to my quote. the biggest headache with them is losing the grub screws so you end up with a few nuts and no means of locking them and attaching the fly leads. as a get out, you can use a short 4mm screw with a locknut.
Reply to earthing the SWA cable armour in a rotary switch? in the UK Electrical Forum area at ElectriciansForums.net
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
