ipd1961
Hi All
I am currently engaged in the 1st fix of a new 3 storey building which houses 12 1 or 2 bed flats. Each flat has its own Consumer Unit (fed from a meter on the ground floor) with a gas and water supply . The stop cock for each flat is located in the airing cupboard so no probs there where main bonding is concerned. The problem I have is each of the gas meters are being put on the outside of the building on the ground floor so do I take my main bond for the gas from each flat to the meter positions? The first flat I have to wire is on the 3rd floor and at the back of the building. I am sure that the gas meters should be closer to the flat but the developer insists they must all be on the ground floor.. Any help would be greatly appreciated
