Earthing | on ElectriciansForums
Discuss Earthing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
Peter Woodford
guys,
If your installing a new circuit into a board and find your gas is bonded but your water isn't can you run a cable from the main stop cock to a local socket to bring the reading down, or does it have to go back to the board
cheers:confused:
If you can't physically see the bond to the Water, your best bet is to put an earth clamp within 600mm of the main stop cock and run 10mm back to the main earth terminal. It maybe that it is currently earthing through boiler pipework.
Reply to Earthing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Any metalwork connected to the MET could rise in voltage compared to true earth under an open supply neutral fault (on TN-C-S), and that would...
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
