Earthing | on ElectriciansForums
Discuss Earthing in the Australia area at ElectriciansForums.net
SSE
I've run an earth 10mm to main water supply in house and there is currently no seperate earths run to bathrooms. All circuits are rcd protected and when i checked continuity at sink pipes using flying lead the reading was fine but when i checked at the shower there wasn't any continuity. Checked above the shower and noticed some of the pipes were plastic. I've been told by someone now that I need to run a seperate earth to the shower?? Is this correct?
Hi, steve, thanks for your reply. I should have stated it ain't an electric shower and that it was not the shower I tested but the shower copper pipes. Sorry about that. Does this change anything?
If all circuits in the bath/shower room are RCD protected,and max disconnection times are met,and you have a continuity reading of <1667 ohms between conductive parts within the bath/shower room and metallic pipes entering the bath/shower room you do not need to supplementary bond. If metallic pipes within the bath/shower room are supplied by plastic pipes there is no need to bond.There is no requirement for continuity to any other pipes/sinks etc outside of a special location as defined in section 7 of the BRB other than main bonding incoming services......all of this can be found in the OSG.
As far as i can see the pipes are plastic in the loft to above the shower where they are changed to copper. I think (not sure) the pipework before plastic is copper as well, if that makes any sense? Seems to be this part was done in plastic as it would have been a pain for copper pipework to be put in that angle. Is this normally a done thing?
Reply to Earthing in the Australia area at ElectriciansForums.net
M
Intermittent bad smell Hi I have an intermittent bad smell that's really hard to pin down, I was wondering if I could get your thoughts on it...
MatthewG
M
Question 1 do you prefer buttered, salted or sweet salted? I'm guessing salty 😜 1. Auto range multimeter (used on mains before when testing the...
