Spark1979
You can't bury gas pipe work in the concrete foundations of premises due to movements it's in the gas regulations, you can lay in screed as long as it has manufacturers protection on and is at correct depth
new there was something about not burying it cheers mate.You can't bury gas pipe work in the concrete foundations of premises due to movements it's in the gas regulations, you can lay in screed as long as it has manufacturers protection on and is at correct depth
As an Niceic approved electrician who is now doing his igq in gas bs6891:2005 states under 8.8.1: installation pipe work shall not be buried in concrete slabs. 8.8.2: rigid stainless steel pipework shall not be buried in concrete screeds. Where a pipe is buried in a concrete screed there shall be a minimum of 25mm of cover above pipe
8.8.3: pipes buried in concrete grounds floors shall be protected against failure caused by movement. Joints shall be kept to a minimum. No compression fittings.
Hence gas pipework must be laid in the screed not concrete foundation!
Reply to the thread, titled "Earthing" which is posted in Electrical Wiring, Theories and Regulations on Electricians Forums.
