earthrod depth | on ElectriciansForums
Discuss earthrod depth in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
W
welsh spark
HI all,
Ive just recently completed a new rewire on a domestic property that is a tt system my question is this the earth rod i have installed is three feet long but i can only get about 2 feet of the earth rod in to the ground as all the places i have tried to place it the ground are solid my reading is 90 ohms wich is ok and i cant find anything in the regs that states earth rod depths your thoughts on this please
Welshspark
Reply to earthrod depth in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
There is a section on the mains supply which will give the type of supply as TNS, TNCS, TT etc this indicates the method of earthing
