Economy 7 | on ElectriciansForums
Discuss Economy 7 in the UK Electrical Forum area at ElectriciansForums.net
R
Rosemead
Hi Guys,
New to the forum and would be glad of any help. I Cannot figure out where the immersion heater feed from the E7 Consumer unit CB goes to. There are two Immersion heaters In the Cylinder and the E7 one is not working. I opened up the timer and have L+N supply( from the CB in the Domestic Consumer unit ) and the supplies to the two heaters.
Many Thanks.
start with the reisitance of the element & stat. and work back. don't forget the thermal cut-out, either in the stat or directly in the element housing.
Sorry if I'm missing something here. Just so I understand the problem. you cannot identify the end of the cable fed from this particular circuit breaker within the E7 consumer? Is that a correct statement?
With the greatest of respect. Do you want me to lift up floors and break into walls. If a cable starts at a CU it must terminate somewhere and if not at the timer where. I came on the forum to ask for help
from people who have experience of E7 and are willing to help me with my problem.
Can you post a picture of the cylinder showing the immersions and whatever controls there are.
Also depending on the age of the house there may be an additional switch in the kitchen or another room to allow convenient operation of the immersion. (It has fooled many a plumber and sparky around here)
Reply to Economy 7 in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
He can apply for an E7 tariff with or without storage heaters. It depends on his electricity usage profile on whether this is a good idea or not...
