ECR and EIC | on ElectriciansForums
Discuss ECR and EIC in the UK Electrical Forum area at ElectriciansForums.net
oracle
Kent
I have a Periodic Inspection coming up on a small workshop and the customer has advised me that he has converted the storeroom into an office with new lighting and sockets that have not been tested.
It seems unsuitable to issue an EICR on the whole installation without any previous paperwork or an EIC for a new / existing combination so I'm thinking a certificate for the office and a report for the workshop.
Cost is not an issue with the customer so what do you think?
It is quite common to carry out an inspection & test on an installation (or part of) with no records. In my experience, it is more unusual to have full records.
So just carry on and complete the EICR.
If it was planned to only complete testing on a percentage of circuits (because there are previous records, e.g. last EICR), then I'd make sure to include the new alterations in the testing.
Thanks for the replies but the thing is there is only a sticker on the main DB showing that it was last tested 5 years ago but there are no records, schedules or drawings for either part of the installation.
The entire installation has been done in conduit and trunking, mounted on the surface and is visible throughout. Adding the alterations to the EICR without any paperwork worries me and since it's all accessible should I treat it as an EIC and test it stringently, bringing it up to current requirements? Cost is not an issue.
No. The previous work is nothing to do with you so it would not be appropriate to issue an EIC for it.
Inspect the installation as found with whatever records you have available, same as you would with any inspection.
Note down that recent work has been carried out but no paperwork is available.
Cost not being an issue is irrelevant.
Thank you all for your supportive suggestions. I don't like third party certification at the best of times and EICR including new installation work without any previous paperwork seems an acceptable way to go
Reply to ECR and EIC in the UK Electrical Forum area at ElectriciansForums.net
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
My older card has it but my newer card doesn’t
