EDF meter change fault | Page 2 | on ElectriciansForums
Discuss EDF meter change fault in the UK Electrical Forum area at ElectriciansForums.net
london
Hello guys
EDF came out to a flat and attempted to replace the meter.
I have been called out to investigate there comments which are “unsafe to remove meter, possible borrowed neutral, voltage at meter even with fuse removed (dropped neutral test)”
First off i am currently on site, I removed the fuse and tested potential between N in and N out no voltage.
I then tested all live conductors to earth and no voltage.
Question is what is this dropped neutral test and and I missing something with my testing as I can’t see a problem?
I don’t think it’s a dropped neutral, but because the engineer has said there is a dangerous situation you need to clarify from him what that is.
It’s awkward as you will be last spark on site so you need clarification before you leave.
Reply to EDF meter change fault in the UK Electrical Forum area at ElectriciansForums.net
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
