Efficient storage of solar getting closer | on ElectriciansForums
Discuss Efficient storage of solar getting closer in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I was talking to someone the other day regarding solar storage and he is one of the scientists who is working on this and he didn't think they were close at all to making an affordable system that would be brought out into the market. He seemed to think they are years away.
I did carefully choose the topic of "getting closer" rather than "close" or "very close".
The fact that there is a possible direction of research for storing solar more efficiently and economically than current batteries is promising, but no, I wasn't expecting to be able to pick on of the shelves just yet...
Matthew
Here's a more technical read of the same development
Interesting - this part stood out for me
"Pint’s group is currently using this approach to develop energy storage that can be formed in the excess materials or on the unused back sides of solar cells and sensors. The supercapacitors would store excess the electricity that the cells generate at midday and release it when the demand peaks in the afternoon."
It suggests that we one day see a new generation of solar panels with the energy storage built in.
Matthew
Their energy density is still worse than a lead acid battery and over an order of magnitude less than Lithium Ion (less than 10Wh/kg, versus over 100Wh/kg for LiIon), so I can't see them being the 'renewables energy storage solution'. Conventional Supercaps have fantastic power densities (lots of current in and out) but they're expensive, so if these new silicon/graphene ones are cheap enough, they may be good for covering short term peaks and troughs but probably over minutes/10s of minutes at best rather than hours/days.
Don't kid yourself there Worcester. Manchester Uni is the top ranked UK institution for holding graphene patents at 163 in the world with 6 patents, vs 210 patents held by samsung.
We absolutely suck at anything related to actually commercialising the results of our universities research.
[ElectriciansForums.net] Efficient storage of solar getting closer
http://www.ipo.gov.uk/informatics-graphene-2013.pdf
If and when graphene threads can be produced at a reasonable cost they will make a huge impact on power transmission, storage and capactitors.
Its a way off yet - interesting times tho.
It's not the number of patents that matters, if all the others are dependent upon one key one :)
My interest? My eldest son is just trying to choose which uni to go for for Materials Science, QMC, Imperial, Manchester, plus 2 others, Manchester impressed so far in the materials dept they have 7 scanning electron microscopes and the most powerful tunneling electron microscope in the UK :) - there's only 7 of what they've got in the world atm... plus (compared to a lot of establishments) are pretty good at commercialising what they do.
Graphene is a superconductor at STP, that's what makes it most interesting.
2nd thing to consider, and this gets scary...
The top 5% of undergraduates in India is MORE than the TOTAL number of UK undergraduates.
Reply to Efficient storage of solar getting closer in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Where are you based?
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
