EIC for partial rewire | Page 2 | on ElectriciansForums
Discuss EIC for partial rewire in the UK Electrical Forum area at ElectriciansForums.net
As multimick says, alteration as you have altered existing circuits. To be honest those tick boxes are not really too worth being worried about as the lines between alterations and additions can often be blurry as in this case. What is more important is a clear description of the works in the appropriate section on the cert.
OK. Thanks.I agree with you .
IMO, if you are renewing cables, length by length for the sake of damaged or faulty cabling then MWC. tin hat on
Disagree, 7/029Dave you will be removing an existing circuit, rewiring it with possible differing method of installation methods therefore EIC.
Reply to EIC for partial rewire in the UK Electrical Forum area at ElectriciansForums.net
https://professional-electrician.com/technical/replacing-a-consumer-unit-in-a-dwelling-niceic/ All circuits should be tested
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
