Having just made an alteration to a kitchen circuit, literally moved a socket, the kitchen circuit was not covered by RCD so we installed one externally to the consumer unit as it was an old MEM board, would you issue an EIC or a PIR?
Discuss EIC or PIR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I would have thought a minor works cert would have been enough.You haven't really installed anything apart from the RCD to bring the circuit up to 17th.Having just made an alteration to a kitchen circuit, literally moved a socket, the kitchen circuit was not covered by RCD so we installed one externally to the consumer unit as it was an old MEM board, would you issue an EIC or a PIR?
Neither and EIC nor a PIR, a PIR is only an inspection and test of an installation, and an EIC is for the provision of a new circuit!! I would issue a Minor Works!
Hmmm,
I would say an EIC as you have changed the characteristics of the protection of the circuit by adding the RCD.
BUT thats all IMHO.
an EIC as you changed the protective device(s)
hello....earth fault protection!
Reply to EIC or PIR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
