Eicr, board change recommendation? | Page 2 | on ElectriciansForums
Discuss Eicr, board change recommendation? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You have made a hard choice and made it correctly and I applaud you for that sensible action.
To continue to lower standards to a minimum is not a sound business approach.
I wish you luck in future progress and hope that you can gain a more professional job elsewhere.
Sorry you are out of work now, if karma is correct then you should be able to find something better very soon. I hope this is the case.
Either as an individual or team up with another Spark and approach the local authority for testing contract. You can say that you had joined a company that currently provides this service to them (but don't mention names) and say you left them because of unscrupulous methods and false reporting. Tell them you now know that there is opening in the market for honest testing work at a time when local authorities are strapped for cash. You can say that your individual testing might be slightly more expensive but because you will only recommend truly required remedial work when necessary there will be savings in the long run.
Well it might be worth a try .....
No chance. I suspect the company he has just quit put in a very low price hence their work ethics in the hope of remedial works which probably don't need doing.
Hi every one, one last update.
I went to a job interview today with a local company doing commercial installs and got a call this afternoon saying I got the job. It does not start till the 22nd but I have a agancy job till then so all is good now don't have to do domestic.
Thanks for the advice lads.
That is good news, I wish you well in the new job and I hope that they are working to an acceptable standard.
Well done.
Well done Baker and good luck mate.
Reply to Eicr, board change recommendation? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Pedantic Pirate Pounces Persistently! As my English teacher often said "Always avoid alliteration"
He needs to first be able to confirm the design current (Ib)
