On an installation there are two main switch’s one in a 12 way DB, another is an exel switch fuse supplying two DB’s. What would you put down as the main switch on the cert on page 2?
Discuss EICR certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Reply to EICR certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
