C2
Discuss EICR code Split cpc on ring final circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Depends if it is rcd protected.R2D2 or C3PO
No Westy it's protected by "The Force" Young JediDepends if it is rcd protected.
That is an option if you cannot locate the fault.Why not FI then make ring two 20a radials if space in ccu permits
Reply to EICR code Split cpc on ring final circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
