When doing an EICR what code (if any) would you guys give to a piece of twin and earth cable in a duct outside.
The duct runs from the side of the house approx 10 metres to the detached garage. The cable is exposed for about half a meter where it comes out of house wall where it is clipped and goes into the floor level plastic duct which re-emerges in the garage. Ducting is set in the concrete driveway.
Cable IR tests fine and size/OCPD is fine. SWA would obviously be better but it would likely be a pig to replace. I could easily trunk the exposed T+E before it enters the ground which gives it some mechanical protection but the issue I'm least happy with is i cant see how the duct isn't carrying some water/likely to at intermittent points.
Cheers
Cheers
