Has anyone bought a copy of this NAPIT publication? If so, what are you thoughts?
Discuss EICR Codebreakers: A Guide to Coding Observations for Electrical Installation Condition Reports in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Also things like if your meter tails are over 3 meters without a switch fused isolator then it suggests a C2.
Yeah but why would it be an FI?Thats interesting - especially as the meter tails are not part of the EICR inspection as I understand them. Sure this could be commented on but ..................
as for FI and C2 - they both result in an unsatisfactory ....
It's obviously his opinion and he shouldn't be insisting on something that isn't required. Full of themselves, some of them.There will never be a definitive black and white this is what you must code every item, as there’s to much different opinion.
All you can do is use your best judgment and knowledge of the regulations.
The Niceic inspector came out to an Eicr I did last year and banged on about how you should be making sketches of the layout of the building.
Bear in mind it’s was a rather large solicitors offices.
I don’t recall this being on my testing and inspection exam nor in GN3 or the regulations
That's one good way to go about it, but not a necessity.^^ whether I'm doing a full change or an EICR, one of the first things I do is a sketch layout showing the outlets and lights .... Then I work out which breaker is doing what ...
Yep. It would have taken a bit of time on one industrial EICR I did last year......with over 40 db's.I’ve never felt the need as in large premises it’s not practical and I feel a waste of my time.
Reply to EICR Codebreakers: A Guide to Coding Observations for Electrical Installation Condition Reports in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
