EICR Coding query | Page 2 | on ElectriciansForums
Discuss EICR Coding query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yes, and as I say i know exactly what needs doing to put it right. I just have never come across a board with no main earth connection so am struggling to find the appropriate reg/code.
You need to forget the fact that it's a board, you have a circuit (the supply to the board) without a cpc. Therefore ADS is not being met. The Zs is too high and there is no earth fault protection. Code 2.
None of the final circuit from the board will have acceptable Zs or disconnection times. All code 2.
Reply to EICR Coding query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
i notice you mention "fire rated" instead of "metallic" Are we talking about a metal consumer unit? I know its presumed... but just checking
