Eicr coding | on ElectriciansForums
Discuss Eicr coding in the UK Electrical Forum area at ElectriciansForums.net
Doing a test the other day and found a couple of metal light switches no earth to faceplate just to back box but both lugs were fixed.
What code do you reckon I'm saying 3 but it's a 2 minute job anyway to rectify. Can't recall seeing it before though
Cheers
True but gotta find some faults for my money !
I find it's better to tell the customer there were a few very minor faults that have been rectified.
The faults you mention are not worth the time, effort and ink to note it down plus the time to open a what code debate on here
Quote Bigspark "No code.. Aslong as there is one fixed lug no code required, faceplate cant be taken off until isolated, not to say i wouldnt tell the customer and refer to any manufacturers instruction."
How do you know a switch is safely isolated with out removing it from the box?
You dont without removing testing but how many metal clad consumer units,switch fuses grid switches etc use this method to earth the faceplate. Personaly I earth all metal switches with a flylead but its belt and braces.
Most manufacturers instructions recomend "earthing"
Im not saying i wouldnt put a fly earth lead to it as i 100% would but to fail this on a eicr you must put a reg no aggainst it.! Exacly db covers grid faceplates are good examples
Neither of which ususally have any live terminals on them, therefore becoming just a piece of metal once removed. Unlike the switch which the OP asked about.
Reply to Eicr coding in the UK Electrical Forum area at ElectriciansForums.net
There is no homework, and I'll never see these photo again.
This is a baffling fault I've been fighting with for a couple of weeks now, so I wondered if another set of eyes will help. I installed an EV...
