daverogers
Good evening all. I have had a new customer contact me about a EICR he received. (unwillingly) One of the items in the report is "Cooker switch over hob C2"
Now I agree that the cooker switch should never be over the hob as its not designed to be there ie external influences and you will just simply burn the hell out your arm.
Would you class this as a C2? I can see some reasoning as you can burn yourself and the switch can melt. I have not seen the installation myself so I cannot say.
Now am I correct in thinking there is no need for local isolation of the cooker. A BSEN60898 can be considered the isolator which can be locked off. There is the issue of emergency switching if the designer deems it necessary.
Anyones thoughts on this
cheers all
hone:
cheers all
