A 30mA RCD is going to trip all the same at 199ohms and 250ohms, the only difference between the two is that one is over the 'suggested' value in the regs regarding stability. The fact is, you can get stability from high values, this is just as likely as a high value being unstable (round my way anyway), that is why I would want to check this out before deciding whether or not I would recommend improvement.
I can see the point regarding a C3, and I wouldn't see this as wrong, if the aim was to recommend improvement with a C3 and then check out it's stability I can go with that. Either way though, an s-type up front would be a firm recommendation of mine.
