Good morning,
We have a two-bedroom flat that my wife and I rent out to supplement our income. Following the recent EICR, several issues categorised as C1, C2, and C3 were identified.
I've tries to discuss alternatives with the engineer, particularly concerning the replacement of the consumer unit (CU) due to its high cost. However, I'm not satisfied with the options provided. Could you please share your thoughts on achieving safety compliance without replacing the CU, and costing a small fortune?
On the loose box above the CU issue, it has a bit of play, minor, it is not hanging of the wall!
Quotes asked:
Ultimately, I'm looking to resolve these issues without needing to replace the CU. I appreciate your guidance on this matter.
Please see the PDF as it includes pictures.
Thank you for your assistance.
Lucio
Quotes asked:
- Engineer to provide a quote for removing the door contactor switch to address the C1 issue?
- What would be the cost for securing the loose box above the CU?
- Could the engineer quote for replacing the three B16 MCBs with B10s?
- Is it possible for the engineer to group the two ring circuits and isolate the radial circuit, or group it with a B20 circuit? Please provide a quote for this work.
- Will the proposed solutions from points 1 to 4 ensure compliance and enable the issuance of an EICR?
Lucio
