EICR meter tails coding | Page 2 | on ElectriciansForums
Discuss EICR meter tails coding in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks guys for all your replies, my bad they were 10mm after i checked,
I'm still pretty new to doing ECIR's so don't be to hard on me, iv yet to come across tails that small in my journeys.
the installation has already failed on numerous faults,
An EICR is satisfactory or unsatisfactory - there is no pass or fail!
Can you give us some examples?
sorry i should of said unsatisfactory.
there is no bonding to the gas
there is non ip rated light within zone 2
same light is also broken with access to live parts,
No blanks within CCU,
there is numerous C3's
C1'S then. = unsatisfactory.(2)as well. code 3 is not.
Reply to EICR meter tails coding in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
