Eicr no visible main bond to water services | on ElectriciansForums
Discuss Eicr no visible main bond to water services in the UK Electrical Forum area at ElectriciansForums.net
Port Talbot
Hi all, it's been a while but been busy in work and setting up my fledgling company I have a question, have a eicr tomorrow on a ground floor ex council flat. Had a look round earlier and can't find the main equipotential bond to the water but it is visible at the met in the db, if the bonding is under 0.05 ohm near the stop clock, with the gas bond disconnected can I class this as a c3? The supply is tt BTW not that it should matter, any advice greatly appreciated
Haha, I own a vw polo but far from rusty! I hope you are not implying I'm a cowboy I'm just asking a tricky question, OK so c2
No no it was from a previous thread I posted about seeing this rusty car in Port Talbot and I saw your location.
Reply to Eicr no visible main bond to water services in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
