Eicr no visible main bond to water services | Page 2 | on ElectriciansForums
Discuss Eicr no visible main bond to water services in the UK Electrical Forum area at ElectriciansForums.net
Port Talbot
Hi all, it's been a while but been busy in work and setting up my fledgling company I have a question, have a eicr tomorrow on a ground floor ex council flat. Had a look round earlier and can't find the main equipotential bond to the water but it is visible at the met in the db, if the bonding is under 0.05 ohm near the stop clock, with the gas bond disconnected can I class this as a c3? The supply is tt BTW not that it should matter, any advice greatly appreciated
Agreed, just dont want to charge extra to install a bond from the db, although wouldn't be much cost - about 15m cable plus trunking, just been having a mare lately, 2 Rcd faults in a week or so, one a mem board with a functional earth causing probs, as I said a new business, just want to ensure everything is cosher, hanks for all replys
Do the EICR and consider remedial costs after and don't be blinded to other matters by proving or disproving the water bond. Me I would get the job done then spend a bit of time on the bond problem.
Oh the joys . If you have looked in all the usual hidden places they may have bonded it in a pipe box going to the upstairs flat . Councils do strange things.
I worked in one where all the rewired cables come down the exterior wall cavities back to CU. Circa rewire 1984.
With all the sticker we have to put on boards these day i sometimes think a bonding location sticker would be a good idea.
Sometimes people don't even know where there water/gas come in.
Yes i know i could make one myself
I agree about the labelling. Would be more use than most of the other labels usually stuck to a board. Here's one I did earlier.
[ElectriciansForums.net] Eicr no visible main bond to water services
Me too. About 15 years ago I submitted a request to the IEE that this should be a requirement and it was put forward for consideration but I received a letter back stating it wasn't necessary, still got it somewhere.
Oh ---- I forgot, the earth to the earth rod is about 10" from the wall, 10mm cable not buried so fine, but an obvious tripping hazard, needs conduit etc but wouldn't a conduit box etc pose more of a tripping hazard? Sorry but everything I see lately seems a mind bending issue
Reply to Eicr no visible main bond to water services in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
