EICR prices - 3 bed semi or per certificate? | Page 2 | on ElectriciansForums
Discuss EICR prices - 3 bed semi or per certificate? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Was referring to Mary Wherry @Des 56.....admittedly nothing to do with eicrs but it made people look at the industry, specifically domestic electrical works
Ah right I understand now:)
I did read of and know of that case,it was a tragedy and this particular case showed that no action would likely ever be taken to make schemes and rogue companies become responsible in the eicr market
Thanks very much for the info
I charge £150 for a standard 1-2 bed flat and £250 for a standard 3-4 bed house, any bigger and it's estimated on time or per circuit! I seem to do a lot of houses but not so many flats, mainly student let houses too.
I was asked if I can test a domestic property in Liverpool yesterday, I said yes i can and told them I charge £120 for an EICR. They then replied
"£100 sounds better"
I replied saying no I charge £120 for a domestic EICR (Which i think is pretty reasonable?)
They did not reply!
Out of curiosity how much do you charge for a domestic EICR and what area are you from?
I Feel like £100 is too cheap for a proper inspection and test?
and do any of you negotiate on price at all?
I set a price and dont move from it as i think if i could do it any cheaper (without doing myself over) then I would? If i set a price and then lower it was i not overcharging in the first place?
Curious to hear other opinions!
£200 minimum. Location is Derry in the north-west of Ireland.
Reply to EICR prices - 3 bed semi or per certificate? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
Thanks mate for the advice, this is just what I was looking for. I think I’ll have to put some thought into the domestic route due to the NVQ and...
