Discuss EICR Service Head in wardrobe. in the UK Electrical Forum area at ElectriciansForums.net
Well I'm just being honest. Sometimes I might shift a meter if it's in the way and I pull fuses of course! But yeah I totally overlooked the fact that I can't touch those meter tails. I just want to get things right for the customer but I can see I need to pass on this job until this is fixed.If your planning to do something of dubious legality it's best not to announce it on a public forum.
Yeah of course. Your right. I mean someones messed about with it, I'm sure the supplier wouldn't have fitted them that way? Will they agree to change them if they have been messed with? If I code it a C2 where the next port of call. The DNO?
Did far worse that that once. Cut the service cable at the nearest pole, removed the cable, removed the meter and cut out and demolished the wall it was mounted on, then put the whole lot into a cardboard box.What do you think? Wildly reckless? Should I expect any come back?
I'd probably say that's even more of a reason to leave it well alone from a liability point of viewNot sure I would have done that, the fact a tenant was moving in is not your problem.
Reply to EICR Service Head in wardrobe. in the UK Electrical Forum area at ElectriciansForums.net
