L
Leesparkykent
I will try praying for him![]()
What software do you use mate?
None.What software do you use mate?
old school pen and paper then.None.
That just about sums me upold school pen and paper then.
I would agree with allowing 3 hours, including lunch travel snags and writting report i stick with the comment i wouldnt take on more than 3 a day. U said ur not allowed to move fridges what if u cant unplug fridge do you lim L-L on rings.? Disconect any ballast or transformers for L-L on lights.? Does each flat have a dno supply
Why would you, EICR should be with no or limited dismantling
I think it was called ecert, I didn't install it the company who's license I used did. Could check my iPad if you want?Kate, what software did/do you use on the iPad?
I actually quite enjoy doing periodics/EICRs, so long as I get a reasonable balance with other work. If you take the process of inspection seriously, it really helps you get to understand/interpret the Regs ( which of course you should already have a good understanding of to do this type of work!)
I use the nic online for mine tooNo, 'twas just idle interest that it might be Icertify or something similar. I use the NIC online certs but they are not great and certainly no use "on the job". Cheers.
Yep, not worth the paper they are written on. lolI like them, I can get a few hours sleep in the van.
Was cheaper than an ipad and he said I could get one of those fancy book covers on Amazon. Would be worried using it on site in case someone took a shine to it.Depends what you paid for it! What a plus for use on-site, does it come with batteries?
