EICR's after 1st Jan 2019 .... | Page 2 | on ElectriciansForums
Discuss EICR's after 1st Jan 2019 .... in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
So you are doing an EICR next year and you are inspecting a consumer unit with these 2 "makes" of RCBO's in it ...
[ElectriciansForums.net] EICR's after 1st Jan 2019 ....
So is it:
I've given you a disagreed because I don't think I've ever seen an EICR where different OEM parts have even been commented on , let alone coded
I report on them all the time.
I had a Hager rcbo stuffed into a 3 phase dorman Smith DB which did not line up on the bus bar properly so it was coded.
^^ er and your comment is?:)
I don't have one I did have one, but thought better of it and pressed the button, does that answer your questions, Murdoch and Anthonybragg and to add I couldn't really give a ---- about top poster, so that remark was uncalled for.
No code for me as lewden brought CGD ages ago. They are manufactured in the same plant they’ve always been and a simple email to lewden will confirm they are designed for boards labeled as CGD. No different to when Schneider brought square D.
As long as they are not subject to a product recall. for whatever reason, if my memory serves me well.
I don't have one I did have one, but thought better of it and pressed the button, does that answer your questions, Murdoch and Anthonybragg and to add I couldn't really give a **** about top poster, so that remark was uncalled for.
Was only jesting with you Pete as I am sure were ESSEX and Murdoch, Sorry if you didn't see it in the same light.
No comment required on cert for this example as they are the same, some manufacturers gear is type tested for use in others an example being surge protection devices ltd whos spds have been type tested for use in lewden/cgd boards.
The manufacturers of those two RCBOs have made a conscious attempt to differentiate them selves from each other by branding them differently.
It's not for the end user, installer or even inspector to jump to the conclusion that just because both manufacturers have used the same style of casing, which may well be made by the same manufacturer, that the product inside is exactly the same - I think I would struggle to form a decent court-worthy argument that the reg relates to the manufacturer of the casing and because they look similar the different brands can be ignored.
Substituting a product which looks similar but carries a less well known brand is almost always done for financial reasons and I think a judge or jury would be likely to pick up on that.
C3.
You know I think we can get a bit carried away at times on here, I'd love to know where two different makes of RCBO in the same DB, both correctly fitted and of identical dimensions and characteristics could result in an installer or inspector ending up in front of a judge and jury !
Reply to EICR's after 1st Jan 2019 .... in the UK Electrical Forum area at ElectriciansForums.net
Here the BPG#4 is useful, it is not a statutory document at all, but it provides good guidance as to what can reasonably considered as C1/C2/C3...
For the OP in case they have not come across them so far, the free BPG can be found here...
