EICR's - circuits that prove impossible to trace | on ElectriciansForums
Discuss EICR's - circuits that prove impossible to trace in the UK Electrical Forum area at ElectriciansForums.net
Dave_
Hello all,
just wondered what you do when you come across circuits on a EICR that are not labelled and you can't trace them?
I do this:
where you have 'extent of installation covered by this report'
I put - 'as per circuit schedule'
in the circuit schedule I note down 'Unasble to Trace'
am i leaving myself open??
thanks in advance,
Dave
So basically then if its not marked, dont attempt to find out what it is? what is the whole db is not labelled?? there must be some sort of crossover point where you say yay or nay!
If you have made efforts to trace the circuits and cannot find the outlets then this would be an operational limitation, and should be noted in limitations.
The test results would identify that it was an untraceable circuit.
and in coding it it would require further investigation.
easiest way is to leave the circuit de-energised and wait for the customer to phone and tell you what's not working anymore. if they don't phone, then it's probably disused anyway,
Reply to EICR's - circuits that prove impossible to trace in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the reply littlespark. Yes the works have been carried out. Surely it is fraudulent because basically the document is Not...
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
