EICR's - circuits that prove impossible to trace | Page 2 | on ElectriciansForums
Discuss EICR's - circuits that prove impossible to trace in the UK Electrical Forum area at ElectriciansForums.net
Dave_
Hello all,
just wondered what you do when you come across circuits on a EICR that are not labelled and you can't trace them?
I do this:
where you have 'extent of installation covered by this report'
I put - 'as per circuit schedule'
in the circuit schedule I note down 'Unasble to Trace'
am i leaving myself open??
thanks in advance,
Dave
Slightly off topic but I worked for a large organisation and they could not work out why they had so many mobile phones on contract. They sent around a memo asking for the phone numbers that were wanted. They ceased the contracts on the others, about 200 phones. They did not get one complaint. They then tightened up on their leaving procedures to get company property back.
In the Extent of elecrical installation i type: Complete electrical inspection and test as far as reasonably practicable.
If we can not find a circuit we then put in the circuit detail: Unable to locate
Then defect it as a F/I
hope this helps
Yes you can only spend so long trying to trace a circuit then mark it down as further investigation required.
you shouldnt be tracing them just mark it down on the sheet
hhmmm
Its part and parcel of an EICR IMO.
Although we did agree with one client to trace all circuits first as 90% of circuits where not labeled in one large warehouse we did, took about a week!.
i wouldnt say its part and parcel of a EICR , unless you agreed with the client to do it and test 100% and in daves case if he did not say to the client that he would identify circuits that are not marked then its not down to him to find them and label it
Fair enough. Theres no argument as I can see your point. We just do it different ways, Ill spend so long looking before putting it as untraceable. As you say better to agree with client before hand then everyones square. :icon4:
easiest way is to leave the circuit de-energised and wait for the customer to phone and tell you what's not working anymore. if they don't phone, then it's probably disused anyway,
Be careful when leaving circuits turned off I came across an untraced circuit that turned out to be the pump for the septic tank !!!!!!!!
You found out where it went though.
Sometimes if you HAVE to find out, it's the only way.
I got in trouble for blacking the local pub out! We had four pubs on our private network.
Turn the supply off, wait for the shout. Go to the pub and test the supply was dead and the beer was good.
Restore the supply and go back to the pub to make sure the supply and the beer was OK.
HIC!
HIC!
Sure did find it, but not until the septic tank had over flowed !! The S*it really did hit the fan !!!
I would put it down as a c3 and further investigation required. As mentioned further investigation is on all EICR forms. Don't think I agree with the turning it off and seeing what happens technique. Could be very costly and dangerous.
Reply to EICR's - circuits that prove impossible to trace in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the reply littlespark. Yes the works have been carried out. Surely it is fraudulent because basically the document is Not...
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
