Eicr's | Page 2 | on ElectriciansForums
Discuss Eicr's in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the limitation for testing I put: Where lamps, neon lights and/or equipment with electronic sensitive components cannot be disconnected, carry out insulation resistance test between line & neutral connected together and earth at 250 Volts.
Reply to Eicr's in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
