elec. power to a garden shed | on ElectriciansForums
Discuss elec. power to a garden shed in the UK Electrical Forum area at ElectriciansForums.net
ondro
London
Hello,
I have following scenario, 20A circuit breaker in the CU. 3 x 2.5 SWA cable feed to a garden shed CU. In the shed CU I have 0.69 ohm on the income cable. On the shed are two 16A radial circuits of socket outlet. When I do Ze on the sockets , I get 2.9 ohms.
The radial circuits have 2.5mm2 flat cable no longer than 5m from the shed CU.
Any idea why is the reading so high please?
is there a RCD in shed? this could cause a high reading if using no-trip EFLE test. try doing the test this way to eliminate the possibility. ( use the hi-current 2 lead test ).
[ElectriciansForums.net] elec. power to a garden shed
Hello,
What do you mean "I have 0.69 ohms on the income cable, and Ze at the sockets"???????
Reply to elec. power to a garden shed in the UK Electrical Forum area at ElectriciansForums.net
Thanks for that guys I was more thinking about difference in potential between the tub and wet paving flags . The tub is plastic . But it’s the...
