brucelee
well done mateyHad my assessment today with Elecsa all went very well ,now im registered yeeha.Got an A
what jobs did you use for the assessment?
I got the socket & see CB200 from that online site with a name like siswww (can't remember exactly, but it will be easy to find, just google the check box or any of the popular meter brands like Fluke/Meggar. They are actually part of Edmundson) The CB200 cost me around £80 delivered, which I think is a very good price and it will do everything you need for a typical multifunction tester. The only problem is it will trip the rcd when checking the rcd tests (and high current loop test) so you will need to install a non-rcd socket next to your consumer unit and label it 'TESTER ONLY'
If you really don't have a non-rcd protected way on your consumer unit then maybe the more expensive check boxes will deal with this problem: I don't know.[/QUOTE
cheers mate
i know the site you mean
my consumer unit is fully protected and there are no spare unprotected ways so i will probably have to get the more expensive one i will see what elecsa say thanks for replies
should i get a filing system e.g. for certs, H&S file, risk assesment etc so it loks more organized also is it ok to use a fluke T5 -1000 as my voltage indicator ?? gs38 says its better to use one without multifunction dial as the t5 has? and is it better to use a proving uni rather than a known supply? for assessment cheers
