I got the socket & see CB200 from that online site with a name like siswww (can't remember exactly, but it will be easy to find, just google the check box or any of the popular meter brands like Fluke/Meggar. They are actually part of Edmundson) The CB200 cost me around £80 delivered, which I think is a very good price and it will do everything you need for a typical multifunction tester. The only problem is it will trip the rcd when checking the rcd tests (and high current loop test) so you will need to install a non-rcd socket next to your consumer unit and label it 'TESTER ONLY'
If you really don't have a non-rcd protected way on your consumer unit then maybe the more expensive check boxes will deal with this problem: I don't know.
Oh, and it seems you only need to check your meters every three months, not every month as I said earlier.
If you really don't have a non-rcd protected way on your consumer unit then maybe the more expensive check boxes will deal with this problem: I don't know.[/QUOTE
cheers mate
i know the site you mean
my consumer unit is fully protected and there are no spare unprotected ways so i will probably have to get the more expensive one i will see what elecsa say thanks for replies
should i get a filing system e.g. for certs, H&S file, risk assesment etc so it loks more organized also is it ok to use a fluke T5 -1000 as my voltage indicator ?? gs38 says its better to use one without multifunction dial as the t5 has? and is it better to use a proving uni rather than a known supply? for assessment cheers
Well done Sparky83!
I joined ELECSA about 3 months ago. They too phoned me and said I could be assessed the next week! I had to put them off so I could get all the prep work done, but it was only 3 weeks later when the assessor came out though. Yes I had the energy saving lamps question too! (Had to look it up in the Part P Guide!!) The assessor was fine about it though.
Can't remember having any probs loging into me account with them Like. Give them a call, I've found them very helpful!
Brucelee, have a look at the "CalCard" in the ELECSA Shop. A handy 'quick check' for your tester!
I have mine on the 11th October, I particularly liked the tip on storing books in a man bag and folder for certificates, it sure would give a good impression.
Good luck!
hi mate cheers
seen them ok for continuity and insulation resistance but you also have to do zs and rcd and my ccu all protected by rcd so cant do the full zs test on my sockets as it will trip rcd
as for the question on energy saving lights is it not 1 out of every 4 need to be energy saving ??
Why join a money making scheme anyway? I have been working, self employed and subbing for 10 years and if anyone wants proof of competency, I show them my JIB card which costs me £30 every 3 years and that beats them into submission every time.
still need to notify jobs in some domestic settings, and tbh i don't fancy the £150 labc want to charge me for each job.
A JIB card aint going to satisfy the part p patrol though. Agree with what you say regards competency.
But as cagedanimal says, its cheaper than having to pay LABC charges each time you do some nitifiable work.
I had mine earlier this year, got myself into a bit of a state beforehand but soon realized it wouldn't be that hard. Make sure your meter/s are up to date with calibration cert, stay calm and think about your answers and you'll be fine.
Sound advice from UKPABLO. They asked me much the same - telling him that he's a **** and taking him down the pub also helped I found!!
Elecsa assesment Monday, only registered yesterday!!
Business Related
Sparky83,
mcummins7,
