Electrian gone AWOL | on ElectriciansForums
Guest viewing is limited
Discuss Electrian gone AWOL in the UK Electrical Forum area at ElectriciansForums.net
J
Jamesmf
Hi,
I've had an extension built and the 2nd fix electrical is all done and all the electrician needs to do is test and issue cert. Problem is I can't get hold of him.
I have tried asking other electricians if they will test but all so far have refused as they didn't do the design and install. Its all that's holding up my completion cert. from the council.
Other than track him down, what can I do? I have photos of 1st fix and the design, which I guess is no good.
Cheers
James
Have to say, this rings alarm bells that the electrician wasn't actually a Part P scheme member which is why he's now gone to ground. What's the financial situation here?
Hi,
Cheers
James
You should have held 20% of the job price back until he handed over the paperwork, you won't make that mistake again, sounds like you have had some jack the lad around doing a foreigner lol.
Well, it's not often that you'll hear this said on here, but keep it that way. He'll soon resurface when he realises he's light in the pocket.
In the meantime, keep an open channel with your BCO, tell him the score. You're right, no-one else is going to give you an installation cert, but BC *might* accept a Condition Report (EICR) under the circumstances, in which case post up your location and I'm sure one of the trustworthy members on here won't be too far away to assist.
bear in mind that an EICR is a BS7671 certificate. the difference being that it's a condition report, not an installation certificate.BC will quite likely accept it if you explain that the installer can't be contacted.
You lot are rotten the poor electrician could be dead for all we know!
I have never known an electrician do a runner before getting paid, something doesn't ring true here.
That thought has gone through my head, too.
Reply to Electrian gone AWOL in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
Recommended Sponsor News
Hi everyone,
